Results 1 to 10 of 12
Thread: debating on how to level ground
    Default Re: debating on how to level ground
    I do all of my grass removal and leveling with a sod cutter. I use dirt on a regular basis to fill in low areas. I then drive the sod cutter over the fill several times. I use the cutter with the blade up and blade gear disengaged. It makes a great packer.
    Perfectly level and very smooth is a good way to start. The sand should be a very even cushion for the liner. The dirt needs to be flat, level and smooth. It is well worth the extra time.
    Best of luck, Dennis
    tulsa, ok, usa.
    I had decent luck using our little roto-tiller to loosen the top clay (no soil, lol). it made for much easier removal of large amounts of soil, still hand to do a ton of hand work. Many bags of sand and the 2x4 pivoting from the center helped het a smooth bottom. This was for our old sofpool, so traditional AG's may need something different.
    Covington, LA
    ok i bit the bullet and rented one of the small bobcats for sat. also found out that the pools here have to be 10ft from the back property line and 5ft from the side.
