Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: Pool water is green
    May 2014
    Texas
    Unhappy Pool water is green
    We have shocked- adjusted ph and brushed until our muscles ache but still can not get a blue clear pool. any suggestions?
    Default Re: Pool water is green
    We will need more information than that to be able to help. Tell us about your pool --- type, volume, type and size of pump and filter and exactly what all you have put in it, meaning ingredients and not just 'shock.' Do you have a test kit? What kind? Can you give us some current water testing results taken with a drops-based kit?
    Welcome to the Pool Forum!
    May 2014
    Texas
    I have put in baking soda, shock-our pump is a hayward sand-we use the drops test kit and up until today our PH was at 7.6-currently it is 7.2. Our chlorine was good yesterday but no chlorine today. Our pool is inground-don't know the exact volume but it measures 30x9 and is 8 ft deep and 4 foot shallow end
    In ground -vinyl -sand filter-skimmer tabs 30,000 gal and is 16 ft wide 36 ft long
    1. What drops kit?
    2. Get a cheap local OTO / phenol red kit and 12 gallons of PLAIN 8% bleach from Walmart or equiv.
    3. Add chlorine in 3 gallon doses each PM, till the green turns gray or brown. Test chlorine beginning the 2nd evening; skip chlorine dose if OTO test result is orange.
    4. Stop adding other chemicals unless pH is below 7 or above 8. Only test pH when OTO result is medium yellow or lighter.
    May 2014
    Texas
    We use the HTC OTO/phenol red kit and our pool is a 30,000 volume pool-(my husband just told me that). I may have gotten that wrong before. Will my water really turn orange?? Thanks for your help
    Pam
    Your pool water won't turn orange. He was talking about the test sample!
    May 2014
    Texas
    Red face Re: Pool water is green
    Oh my gosh!! I am really not that crazy!! lol But I did read that wrong -thank goodness! But am I reading it right that the water will turn gray or brown??
    Dead algae may be bluish gray or brownish before the filter removes it.
    May 2014
    Texas
    The pool dimensions on my profile are wrong. How do I change this? --(9x30 inground pool ~10 gal, sand filter, skimmer tabs)~~ Our pool is 30,000 gal and is 16 ft wide 36 ft long.
