Re: Pressure question, and when do you replace sand?
If the pressure is low and flow is low, you usually have a water intake problem. This would be between the pump intake and the pool. High pressure and low flow usually indicates a problem between the pump outlet and the pool.
Check for dirty skimmer or pump baskets, closed valves, leaves or debris covering the drain, leaking skimmer basket lid etc.. Does the skimmer basket fill completely with water with no bubble?
