Thread: Order of tests?
    Mar 2014
    NC
    Default Order of tests?
    In what order do you do your water tests? Even with rinsing the comparator tube, will a preceding tests taint the results of the previous?
    Curious.
    25,750 ga 18x36 Rectangle IG Vinyl liner; Hayward 250 sand filter; 1.5 hp pump. PF=4.4
    Default Re: Order of tests?
    As long as you rinse well, it doesn't matter. I use an OTO/ phenol red kit for day to day quick tests of chlorine and pH. I only test alk maybe a time or two per month, calcium maybe once per year. ( I have an AG pool and don't use cal-hypo.) I test CYA frequently upon opening til I get it where I want it and then maybe twice more total throughout the summer.
  1. When To Do The Other Tests
    By jhk49 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-19-2011, 12:01 AM
  2. Before I order is this the right Kit.
    By freddyttt in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-18-2008, 05:47 PM
  3. How often to run tests?
    By ePoolUser in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-06-2006, 04:30 PM
  4. Alk/PH Which order?
    By cav in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-20-2006, 05:38 PM
