Results 1 to 10 of 28
Thread: Brand new and overwhelmed above ground pool owner...
    Default Re: Brand new and overwhelmed above ground pool owner...
    Quote Originally Posted by JoeJet View Post
    Free Chlorine 1
    Total Chlorine 6
    I certainly hope this is testing error. It would NOT be good if you really did have a CC reading of 5ppm!
    FC+CC=TC.
    May 2014
    Hmmmm
    3 x 0.2 = 0.6
    Not 6
    My Bad.
    9k gallon 21' AG pool. PF=13, Hayward Power-Flo Matrix 1.5HP, Hayward XStream CC15093STL, Breeze 320 SWCG, Aquabot Pura 4Xi, Solar-Cell Sunblanket
    3 x 0.2 = 0.6 Not 6
    May 2014
    I'm back! Lots of rain this past week so basically I've been maintaining.
    Here are this mornings readings:
    2.8 Free Chlorine; 0.4 Combined Chlorine; 3.2 Total Chlorine
    7.4 PH
    90 Total Alkalinity
    35ish CYA
    So do I just keep throwing in Dichlor?
    Thanks,
    Joe
    Yes, you have some room to let your CYA rise a bit so you can continue to use dichlor. Look at your manual for your SWCG. It will tell you how high the CYA needs to be for your unit. Once you get it at that point, then just use your SWCG.
    Just use a 10mL sample when you test chlorine instead of a 25mL one. It will make your testing reagents last longer. You can multiply the number of drops by 0.5 instead of 0.2.
    May 2014
    So we screwed up last night...
    After an amazing day in the pool with family and friends I shocked the pool hoping to finally get the CYA to the right spot. Sadly my wife shocked it this morning too.
    Here are the readings:
    Free Chlorine: 10.4; Combined Chlorine: .8
    PH: 7.2
    Alkalinity: 90
    Calcium: 100
    CYA 40
    Sodium: 600
    I measured Sodium in anticipation of starting the generator but I'm not doing anything until I hear from you kind folks.
    I hope we didn't mess things up!
    Thanks,
    Joe
    No problem; you can even continue swimming!
    (You may want to use the 10ml sample to test chlorine (1 drop = 0.5 ppm), so your reagents will last longer.)
