Results 1 to 9 of 9
Thread: White Cloudy Water
    May 2014
    California
    Default White Cloudy Water
    Hello: I have very cloudy/milky white water, I think because I mistakenly added PH minus and calcium increaser at roughly the same time, and I think I read somewhere that the combination of the two can cause very cloudy water. Now that has happened, and I am wondering what (if anything) I can do to clear up the water. Thanks!
    Default Re: White Cloudy Water
    Can you give some additional information, please. What kind of pool, volume, type and size of pump and filter. Exactly what all you have added to the pool, meaning ingredients and not just product names. Also, do you have some current water testing results taken with a drops-based kit and what kind of kit?
    Then, somebody here can better advise you.
    May 2014
    California
    I have an above ground vinyl (doughboy) pool, 16X32 oval. I have Taylor test kit, and latest readings showed a PH of 7.6, alkalinity of 80 PPM, chlorine of 6 PPM. I have a sand filter about 2 feet in diameter (I am not at home so can not look to see the exact size.) Do you know if adding calcium increaser at roughly the same time as adding PH minus will cause cloudy water, and if so how to clear that up (run the filter non-stop?, add a certain chemical?, or if I need to drain and re-fill with new water?) Thanks!
    May 2014
    California
    Unhappy Re: White Cloudy Water
    Yeah, adding the calcium increaser was a mistake due to a mis-labelled tub (my mis-labelling.) Though even with a vinyl pool don't I want to have a hardness over 100? (Right now mine is about 40 ppm.)
    My CYA reading is very low (below 10) - I actually thought I was adding CYA booster when the calcium boost was added by mistake. Now I figure I'll wait to see if I can get the water to clear up before adding more CYA - I have those granules that take about a week in the filter to fully dissolve, and with the pump running and frequent backwash I figure I will wait. But I keep my pool covered even during the with a solar cover, so chlorine loss is not much of a problem right now (not using hte pool yet, so not uncovered during the day.) Though I have run the pump a ton for the past week and it does not seem to be clearing up the problem at all. I added some liquid clarifier a week ago and that seemed to do nothing, and I have tried adding a cut of DE to the filter a couple of times now with also very little results. Which is why I am wondering if I am going to have to go the drastic step of draining and re-filling hte pool, at which time I'll probably get a ton of wrinkles in my liner
    Maybe try a dose of 60% Polyquat to see if that will help. At times, it can be a fairly effective clarifier. Look in the Amazon store link in my signature so you can see what you need to buy. May be able to buy it locally but don't buy any other type of algaecide.
  1. White Cloudy Water
    By ScosheOwn in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-04-2014, 07:28 PM
  2. White cloudy water
    By bb158 in forum Dealing with Algae & Slime
    Last Post: 06-07-2013, 10:16 AM
  3. White Cloudy water
    By billbeard78 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-07-2012, 10:49 PM
  4. White cloudy water
    By PoolParadise in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-21-2011, 01:09 PM
