Results 1 to 5 of 5
Thread: Loop Lock Cover
    Mahwah, NJ, USA.
    Default Loop Lock Cover
    I purcahsed a loop lock cover from my pool builder and they installed it. Ary you supposed to receive a tool to screw the anchors back into the pavers?
    Indiana.
    Default
    Yes. A big Allen wrench.
    Connecticut.
    Default
    Standard run of the mill 1/4" hex (allen) wrench. if you didnt get it, you can get one at a local hardware/home improvement store.
    If you are very careful, you could technically use a drill with the allen/hex wrench bit in it, but if you overdo it you'll pull the anchors out of the decking. Be forewarned if you try it that way
    -Chris
    MarkC is offline Registered+ Weir Watcher MarkC 1 star
    Default
    Put a tiny bit of grease on the threads before you screw them back in. Mine use to seize up during the summer and when I tried to raise them in the fall the whole anchor would spin if they were stuck.
    Default
    I use my portable drill with the tensioner all the way down to 1. This way, if I overdo it, nothing bad happens. Using the drill is much faster than screwing all of the anchors down by hand. I haven't used the tool that the company gave me since the first year.
  1. Please help with choosing Loop Loc cover
    By TomC in forum Pool Equipment & Operations
    Last Post: 08-10-2011, 09:30 AM
  2. Loop loc like cover for daily usage?
    By grido in forum Pool Equipment & Operations
    Last Post: 08-03-2011, 01:39 PM
  3. Loop Lock Cover Cost
    By CJDahl in forum Pool Equipment & Operations
    Last Post: 09-21-2006, 12:43 AM
  4. Loop-Lock Repair
    By halds in forum Pool Equipment & Operations
    Last Post: 05-11-2006, 02:41 PM
  5. Loop Loc cover question/advice
    By rtpatter in forum Pool Equipment & Operations
    Last Post: 04-06-2006, 02:49 PM
