Thread: Jandy DE filter
    JonnyG is offline Registered+ Thread Analyst JonnyG 0
    Default Jandy DE filter
    Hello all!
    Just finished having my IG shotcrete pool installed (30,000 gallons). It took forever for the pool company to come and start up my equipment (over 7 days) from when I had water put in the pool. It will probably take another week or tow for "orientation". In the mean time I have no documenation on how to vacuum the pool. What specifically I would like to know is the valve setting and where to connect the vacuum hose. Here are some specifics -
    1) Jandy 60 sf DE filter with jandy multiport valve
    2) MDX debris removal system
    3) Mars Booster pump cleaner with its own connection
    4) I have 3 skimmers (2 for the filter and 1 for a sheer descent)
    5) 6 wall returns, 3 solar recircluating floor returns and a main drain
    6) I also have a round vent with a part grid on the side wall in the deep end (looks like the main drain but its on the wall)
    So I did not want to use the Mars cleaner until the orientation happens but the company gave me a flexible hose and manual vacuum head. Heres my questions -
    - Where do I connect the flexible hose? for the vacuum
    - What valve setting (if any) should I use for vacuuming the pool
    The pool is not that dirty, just dirt from the pipes during construction which I have mostly brushed to the main drain. I just ahve a few spots that I can not brush well which I want to vacuum up.
    Thanks for your advice and let me know if I need to provide any more information
    JonnyG
    Downingtown, PA
    Default Re: Jandy DE filter
    The vacuum hose fits into the opening under a skimmer basket.
    Outside of Philadelphia, PA
    18' x 40' IG - 22K gallons
    Sylvan Gunite Pool (1979)
    Plaster re-done (1997)
    48 Sq Ft Hayward D.E. Filter (2003)
    1.5 hp Hayward Super Pump (2006)
  1. aquarite and jandy
    By boscogabby in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 02-05-2007, 02:30 PM
  2. jandy conversion to PDA
    By Abish in forum Pool Equipment & Operations
    Last Post: 01-07-2007, 10:33 AM
  3. Replace Jandy Ray-Vac?
    By ChiInSFO in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-24-2006, 01:12 PM
  4. No backwash procedure on Jandy filter
    By kearpaul in forum Pool Equipment & Operations
    Last Post: 06-28-2006, 11:17 PM
