Re: pool pump size for 12.5k gal pool
Ben , correct me here if I'm wrong, or just delete my post. I had a discussion with a Pentair rep about adding some DE to the cartridge filter. He said that cartridge filters filter better when a little bit dirty. So they recommend on start up to add a little DE to jump start this process. Since my current cartridges are a couple of years old, I no longer do this because I never really get them that clean. If you do add DE just add a little through your skimmer line, maybe a half a cup.
On another note, I must say that my 2 speed Whisperflo pump is great. When on low speed, which is almost all the time after initial cleanup, it is 1/4 horsepower. Enough for a good flow through the 6 returns but not enough to get water up to the slide, for that I run it on high, which turns it into a 1 1/2 horsepower pump. This is plenty for my pool. It's a simple pump with no fancy electronics to burn out.
Tom
20'x42' L' 41K gal IG vinyl pool; trichlor feeder, bleach; Pentair 420 cartridge filter; Pentair Whisperflo 1.5hp 2 speed pump; hrs; TF-100, CYA test; city;PF:2.9
