Thread: Intermatic timer trippers
    ScottS is offline Registered+ Thread Analyst ScottS 0
    Covington, LA.
    Default Intermatic timer trippers
    I recall someone last year mentioned they had a few sets of the Intermatic trippers for the T100 series of mechanical timers. The trippers look like these:
    If you have a pair or two that you would like to get rid of please let me know I will rid you of them . I did find these online but the shipping/handling charges on such small items was astounding at near $10. I couldn't find them locally.
    Thanks in advance!
    sailork is offline Registered+ Thread Analyst sailork 0
    Houston (Clear Lake area), TX
    Default Re: Intermatic timer trippers
    I bought them at Home Depot in Houston for about $2. The pair were in a small factory sealed plastic bag hanging from a rod with the other intermatic stuff. They were not exactly packaged for retail so it took me a second to figure out that they were what I was looking for. If you've got a home depot locally it might be worth swinging by.
    22,000 gal gunite pool, 1.5 hp pump, DE filter, and dreams of a SWG.
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    I got my extra set at ACE Hardware by the other Intermatic stuff. The guy didn't know what I was talking about and said they didn't have any, but I just happened to notice them on the bottom shelf...they were in a small bag...an on and off in the set. I think they were about $3-4.
    Sherra
    Kershaw County South Carolina
    (previous AG pool owner)
    Downingtown, PA
    I know Leslie's carries them, I pickd up a second set there. I think there is a free shipping promo on web right now for them, not sure though.
    Outside of Philadelphia, PA
    18' x 40' IG - 22K gallons
    Sylvan Gunite Pool (1979)
    Plaster re-done (1997)
    The trippers or 'dogs' as they are sometimes called can be found at most well stocked hardware stores. They are used on time clocks for all sorts of applicatons...not just pool timers. They are usually in the electrical dept. near the timeclocks.
    Covington, LA.
    Thanks for the responses.
    I did some more calling around and found a local electrical supply store that carries them for $2.24 a pair.
    Electrical supply houses carry them as a rule. I have an extra set for my timer that I bought in a pool store.
  1. Intermatic T104 timer and Goldline GL-235 wiring help for bypass mode
    By netprotex in forum Pool Equipment & Operations
    Last Post: 05-14-2012, 12:16 PM
  2. Question and disappointment with T1000 Series Intermatic timer
    By TheGoose in forum In-Ground Pool Construction and Repair
    Last Post: 05-01-2012, 01:37 AM
  3. Intermatic Timer.
    By Phillbo in forum In-Ground Pool Construction and Repair
    Last Post: 04-05-2009, 04:18 PM
  4. Polaris 180 and Intermatic Timer - Quick Disable?
    By aquarium in forum Pool Cleaning: Manual or Automatic
    Last Post: 10-02-2006, 01:47 PM
  5. anyone have time trippers from intermatic timer they will sell to me?
    By tenax in forum Pool Equipment & Operations
    Last Post: 07-05-2006, 08:26 PM
