Last year we installed used above ground pool that was given to us from my inlaws. It is 28' in diameter and 4' deep with a new liner and filled with well water if that matters. It came with a Hayward ProSeries model S108T filter and Hayward Power-Flo XL pump. All last season we could not keep chlorine in it and the PH and Alkalinity were high, however as long as it was vacuumed once a week the water stayed clear. Even when I put three gallon of liquid chlorine in at a time all or most of the chlorine would be gone in less than 24 hours. When we opened the pool up this year other than some very minor algae spots and a little dirt the pool looked ok but it had no chlorine. Almost a month later and at least 16 gallons of chlorine it still will not keep chlorine. Right now I have AquaChek test strips but as of about 20 mins. ago I have a real test kit on order from Amazon. Yesterday morning I put almost a whole container of PH down in the pool along with two gallons of chlorine. Five hours later there was almost no chlorine but the PH was down to the 7.8 range.
This morning when I tested the water this is what I got
PH 7.8
FC 0
TA 240
Stabilizer 30-50
Help please!
) you will still be able to use either one of these cheaper kits as well for quick daily testing. In addition to my Taylor K2006 kit, I use my little kit all the time!
