Thread: Pool cloudiness problem. HELP
    May 2014
    TN
    Default Help with foggy pool
    I have already posted about this, but cannot find it in the forum. A moderator answered and said to check my sand level. I changed my sand yesterday, and it has been running about 13 hours with no visible change.
    My pool has been cloudy for 3 weeks. Ever since I opened it. I have a 5 year old AG 30 ft (20,000 gal) pool with a 1.5 hp Hayward pump. I have a 250 lb 18 in. Sand filter. I have been using the BBB method for 2 years. This year I cannot get the cloudiness to go away. I have been trying to keep the chlorine level at 15 ppm for the last 4 days to kill algae. Here are my numbers, they have been running pretty consistent for the past week or 2.
    As of this morning:
    FC 10 (just added 7 ppm this morning to boost)
    CC 0.5
    TA 150
    Ph 7.4
    Calc hardness 70
    CYA 55
    round AG pool w/ deck
    May 2014
    Plano, TX
    Default Re: Help with foggy pool
    First, test your filter with D.E. Slowly add 1/2 cup of D.E. to the skimmer while watching the return. If you see white or cloudy stuff coming back through the returns, you may hve a filter problem.
    If you don't see stuff coming back, read this thread. http://pool9.net/de-test/
    You may be able to get D.E. @ WalMart http://www.walmart.com/ip/HTH-D.E-Fi...10-lb/20434370 Description is correct, PICTURE is WRONG.
  1. Cloudiness
    By Skelly607 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-01-2013, 06:10 PM
  2. Sudden cloudiness
    By Barry J in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-08-2011, 09:50 AM
  3. The Dreaded Cloudiness!
    By dcsharpe in forum Pool Equipment & Operations
    Last Post: 05-14-2011, 06:48 PM
  4. Sudden cloudiness?
    By Andy Fermaints in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-09-2006, 10:28 AM
  5. please help with cloudiness
    By dhale63 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-02-2006, 10:08 PM
