Results 1 to 10 of 11
Thread: Testing cya with 2006
    May 2013
    Concord,ca
    Default Re: Testing cya with 2006
    ok Watermom, I hear you but how much do I put in I could put in liquid again and that would be faster but if I put in powder it could take weeks. I don't know how much to raise from less than 30 to 50. Like at 13000 gallon what would be the formula for adding the amount?
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
    Adding 2 lbs. of granular CYA should add around 20ppm. It won't take weeks to dissolve but maybe a week. Or, if you prefer, use the liquid. Faster but more expensive. I can't comment on the proper dosing of the liquid, though, as I always use granular.
    May 2013
    Concord,ca
    all I had at the time was 1.5 lbs looks good but the calculator said add 36 oz more so I did. Should be fine
