Thread: battling green algae while cya = 0
    Default battling green algae while cya = 0
    opened up our pool this year and it was much greener than ever before. In fact, we couldn't see the pool bottom. I have a good testkit, initial test showed cya=0. I've been dumping a ton of bleach in the pool and it's getting better but obviously I'm backwashing 2-3 times per day.
    is the idea to bite the bullet on bleach consumption and get the pool clear before adding cya so I won't have to backwash? I also have to add a whole lot of calcium and borax. So what's the right order of operations on the chems?
    tia!
    Pappy is offline PF Supporter Widget Weaver Pappy 0
    May 2014
    Plano, TX
    Default Re: battling green algae while cya = 0
    Tell us about your pool. Above ground or in ground. Concrete or vinyl? What is the make and model of your pump and filter.
    You are right about the bleach, add it after the sun is off your pool, so doesn't get burned up by uv. Pool Doc usually recommends you get the pool clear of algae before adjusting anything else. If your pH is below 7 or above 8, go ahead and correct that.
    Intex 15ftx4ft 4500 gal. 3/4 HP Pentair WhisperFlo pump. Hayward 21" sand filter. Taylor K-2006 & K-1106 kits. PF=27
    thanks, should be in my signature now
    37x20, 28,300 gallon gunite, irregularly shaped, hayward 1.5 super pump, hayward 4820 DE filter, northeast geo
    Welcome back!
    Any idea what your CYA reading was when you closed? Since it is now 0 and you have a big chlorine demand, it's a good bet that your CYA biodegraded over the winter and you are now dealing with the results of that. It may take a lot of bleach to clear the pool of the byproducts, but hang in there and keep hammering it with bleach!
    May 2014
    Plano, TX
    Does your filter have a bypass or recirculate setting? That'll save some backwashing.
    Quote Originally Posted by Pappy View Post
    it does, is that a good idea? I assumed I'd want to get the dead algae out of the pool...or is the idea.
    watermom, my cya was about 40 before we closed the pool.
    May 2014
    Plano, TX
    If the pool still has ANY green, that stops the filter VERY quickly, and you wind up backwashing very little stuff out. Just let it recirculate till it's all the way dead, then start filtering.
  1. Replies: 8
    Last Post: 08-04-2012, 11:43 PM
  2. Battling algae with a cartridge filter
    By McDug in forum Dealing with Algae & Slime
    Last Post: 05-18-2012, 05:16 PM
  3. Cloudy Pool after battling algae.
    By Jbonnette in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-06-2011, 03:51 PM
  4. Battling the mean green...Advise?
    By Muslickz in forum Dealing with Algae & Slime
    Last Post: 09-17-2010, 09:50 PM
  5. Green algae? Mustard algae?
    By AE340B in forum Dealing with Algae & Slime
    Last Post: 07-15-2007, 09:32 PM
