Results 1 to 10 of 13
Thread: New Owner, CDX (PHMB) to BBB Conversion
    Default Re: New Owner, CDX (PHMB) to BBB Conversion
    Unfortunately, the conversion process is slowed not only by measurable Baquacil (PHMB) but all the PHMB residue that's still present, but that you can't test!
    The conversion info is here:
    http://pool9.net/phmb/
    Once you've started, you're pretty much committed to continuing to the end.
    Trying to clean up algae and PHMB is not ideal. Odds are you're going to plug your filter before you're done. I'd recommend that you
    + put the filter on "recirculate" (= bypass filter) and run it 24/7.
    + Get a cheap oto kit, and begin dosing your pool with 3 gallons of PLAIN 8% household bleach EACH evening.
    + Test with OTO before adding a dose; skip the dose of you get a DARK yellow (or orange) OTO result.
    + Once all the algae is dead, begin testing in the AM, too.
    + Once your chlorine 'holds' overnight, turn OFF the pump -- but continue dosing.
    + Wait 24 - 48 hours (while maintaining chlorine!) and see if the algae and 'goo' will settle.
    + If it does, vacuum to waste.
    + Then resume circulating, but put the filter on "FILTER", and try to remove what's left.
    + Once the pool is clear, and chlorine holds overnight (test with the K2006), replace the sand in your filter.
    You *may* have to replace the sand twice, if it's already totally gummed up.
    Good luck!
    May 2014
    OK
    Thanks Watermom...pool is already weird shades of green.
    Pool Doc- I've switched over to recirculate instead of filter. I've been testing every 4 hours with k2006 kit. Here are my results so far starting this morning and my actions taken:
    9pm last night: added 4 gals of 8% PLAIN bleach
    8:00 am
    FC:1
    CC:4.5
    Added 3 Gals of 8% bleach
    12:00pm
    FC:2.5
    CC:2
    Am I adding bleach too often?
    I'll now try not to disturb the water (with vacuum) so all of the dead algae will fall to the bottom and I can vacuum pump to waste.
    Pool was installed no more than 3 years ago, so I can't imagine the baquacil residue would be too bad right?
    If I have the k2006, do I need the OTO kit?
    The water is starting too look clearer, but there is much algae to be killed yet.
    14k gal 24' AG pool; Doughboy AquaView sand filter, Pentair Dynamo pump, K2006. PF=9
    Using an OTO will preserve your reagents. Otherwise, you're gonna burn through them pretty quick. In the case of a Baquagoop conversion, accuracy in chlorine levels is not so critical so the OTO will give you close enough numbers.
    You can't add bleach to often when doing a conversion.
    As long as your chlorine doesn't get into the OTO orange range (or orange tinted yellow), you're not adding chlorine too often.
    3 years of Baquacil? Yeah, the goop will be pretty bad.
    May 2014
    OK
    I'm wondering if I'm getting close to the end of the conversion process...
    I added enough Bleach last night at sunset to raise FC to 15ppm, and CC was at 1.5 when tested 1.5 hours after adding bleach.
    This morning (almost 12 hours later) FC was at 9.5 and CC was at either 0.5 or 1. How close am I? The water is looking very clear now as well. I should also add that it has been raining all this morning, and I didn't know if that would effect the readings, but I got the water sample from about 2 fee below the water's surface. I'm out of bleach now, and am wondering if I should make another trip to the store, and how much I should stock up this time. So far I've went through 31 gals of 8% with a 15k gal pool.
    It can take a LOT of chlorine to 'eat up' all the residue.
    You'll be done when the chlorine level remains nearly constant from late evening to early morning.
    May 2014
    OK
    Excellent News!!!
    Overnight, my FC levels dropped by about 1ppm, if that... and my CC level was 0.5! I think I'm done! Water looks very clear, all algae is dead and on the pool floor ready to be pumped to waste. Next move? What should I do next? Buy CYA? how much and how to add? You can point me to a resource too if there is one on the next steps.
