Thread: New pool pump recomendation
    May 2011
    Default New pool pump recomendation
    I have a 28ft round above ground pool 54" deep that needs a new pool pump. Do you think a 2 speed 1hp pump would be sufficient or should I go with 1.5hp. My filter is the S180T that has flow of 35gpm. I am looking at the
    SP15922s.
    Thanks,
    BigDave's Avatar
    Default Re: New pool pump recomendation
    I think that pump on low should be pretty good. I recall mas985 (whose opinion I trust) recently posted something positive about that line. In the Hayward AG lineup, even the SP1540C should serve without overwhelming the filter, 18" is a pretty small filter and a big pump on a small filter is a bad combination. The 1 HP Powerflow Matrix on high would be too much.
    May 2011
    Thanks for the info
  1. Need new pump and was my old 1.5 HP pool pump too big?
    By deckview in forum Pool Equipment & Operations
    Last Post: 06-09-2012, 09:36 PM
  2. CYA level and chlorine level and pool store recomendation
    By Fishcrazy in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-21-2011, 11:25 AM
  3. Question about heat pump pool heater and fireman's switch on pump timer
    By HuntnHog in forum In-Ground Pool Construction and Repair
    Last Post: 04-20-2011, 08:37 PM
  4. Solar Panel Recomendation
    By jmcst25 in forum Pool Equipment & Operations
    Last Post: 04-14-2006, 12:56 PM
