Results 1 to 10 of 15
Thread: Can you maintain a stable CYA and use an inline chlorinator?
    BigDave's Avatar
    Default Re: Can you maintain a stable CYA and use an inline chlorinator?
    How many ppm of chlorine are you using daily? Trichlor will add 6ppm CYA for every 10ppm FC it adds. It will also push down pH so be sure to have Borax on hand to bring it back up. Also be sure to raise you chlorine targets as the CYA level increases.
    May 2014
    Tampa, FL
    I *just* brought my CYA from 0 to 70 ppm, and am still working on defeating a persistent algae bloom, so I don't yet know what my daily chlorine consumption is going to be. 6ppm CYA to 10 ppm FC is not what I was hoping to hear.
    Hmmm
    Does no one use inline chlorinators and maintain high CYA?
    34' ~17,000 gal IG plaster pool, 1 hp 1 spd Utilitech 0313509 pump, currently running Pentair StaRite PosiFlow cartridge filter, upgrading to Hayward DE3600 DE filter
    BigDave's Avatar
    You will need an unstabilized source of chlorine to win the algae battle.
    May 2014
    Tampa, FL
    Yep, I'm just using bleach now that my CYA is high. I had 0ppm before I used dichlor to bring that up.
    I'm in the process of upgrading my filter, so having to re-do my plumbing. Trying to decide whether or not to install a Pentair inline chlorinator. I'd really like to automate chlorination somewhat if possible, due to an irregular work schedule. Trying to figure out if there's a way around one increasing CYA too badly.
    BigDave's Avatar
    SWCG is a good fit if your pool (and budget) can accommodate. There is a device called the liquidator that may be OK - I haven't heard of any successes with it. Another option is: use trichlor when you're away and keep chasing the required FC for the CYA levels you reach.
    SWCG was one thing that was discussed as an idea in her previous thread. (It is linked up above in the first post in case you didn't have an opportunity to read it.)
    (Lauralee, I like the avatar.)
    May 2014
    Tampa, FL
    Thanks, both of you.
    And Watermom- I've been an aquarium hobbyist for 30+ years and Cardinal Tetras are my favorite fish. Figured that would be a sort of appropriate avatar for here, too lol
    I don't like the idea of my CYA increasing at the rate it looks like it will if I go with the inline chlorinator.
    So I guess this boils back down to whether or not I want to spring for a SWCG. I was all about the SWCG till I realized that the warranties have gone down so much and the cells have to be replaced so often... and that I'll probably need to hire an electrician to wire it. My dad's a retired contractor so he's helping me with plumbing in the new filter, but I'm not confident I want him doing electrical work this close to water (don't know if he'd volunteer to do it anyways...). I'm comfortable with a lot of DIY, but electrical work always just makes me nervous. Totally out of my own Scope lol
    Got some thinking and number crunching to do.
