Closed Thread
Thread: Cementing around the pump PVC plumbing
    beary is offline Registered+ Thread Analyst beary 0
    Dec 2005
    Default Cementing around the pump PVC plumbing
    My pool contractor likes to cement in all the PVC pipe or plumbing on the pump pad. I like the idea of the pump and heater sitting on a concrete pad, but it seems the PVC would be limited in future repairs and modification if they are fixed in the concrete. Is that typical?
    Thanks.
    Beary
    mas985's Avatar
    Pleasanton, CA
    Default Re: Cementing around the pump PVC plumbing
    I have seen done both ways. If you want the pipes in dirt and they have not poured the pad, then ask for it that way. It is a bit more flexible for repairs and you are the customer.
    Mark
Closed Thread
  1. Question about plumbing
    By phikappa in forum In-Ground Pool Construction and Repair
    Last Post: 06-07-2013, 11:59 AM
  2. PVC plumbing
    By ckmoreau in forum Above-Ground Pool Construction & Repair
    Last Post: 05-30-2013, 02:44 PM
  3. How to fix a plumbing leak?
    By JohnASmith in forum In-Ground Pool Construction and Repair
    Last Post: 06-03-2012, 03:21 PM
  4. plumbing question about a Pentair Intelliflo pump
    By jamesdean in forum Pool Equipment & Operations
    Last Post: 08-28-2011, 06:51 PM
  5. Pump plumbing - Straight Pipe Important???
    By jaimslaw in forum Pool Equipment & Operations
    Last Post: 05-22-2011, 10:18 AM
