When you vacuum, does it initially look clean and then a little later reappear? If so, it may just be dirt. When you vacuum, if you don't move the vac extremely slow, some of the dirt gets kicked up into the suspension of the water. Then, when the water quiets down, the debris falls back to the floor. I see this same thing sometimes in my pool if I get in too big of a rush when I am vacuuming.
Welcome to the Pool Forum and thanks for the subscription, by the way!
