Clogged pipe?
Hi all,
Here's my problem: For the first time, I decided to clean my pool cartridges myself this season, because it costs $50 for the pool guy to do it, so I decided to do it myself and save a few bucks. It's a standard Hayward filter, with four cartridges. I took thev lid off, took the bracket off, took the filters out, cleaned them, put them back in, put the bracket back on, and tightened the bracket up good and snug. When I went to turn the pool pump on, I got no to minimal suction. Naturally, I thought I'd done something wrong, so took the filter lid off again, put it back on, etc. No change. Still no suction to clean the pool at the skimmer. Called the pool guy. Told him this story. He said he thought there was a clog somewhere. He used his c02 to blow it out at the intermediate filter leaf catcher. Nothing. Then used his co2 to blow it out at the skimmer. Still nothing. I kept asking him why this has happened simply because I cleaned the cartridges. He didn't know, he kept saying somehow or other, something must have been washed into a pipe or gotten clogged. He never took the filter lid off to check the filters or check to make sure there wasn't anything wrong inside the canister, because he said in his opinion, it wasn't a filter problem, it was a clog problem. He gave up. He didn't charge me anything. All he could do was give me the name of a contractor who could come out and maybe unclog it with his equipment and if not, might have to dig up the concrete pad or go underneath the soil to hunt for this clog or whatever. This he told me would or could be very expensive. All of this happened because I cleaned my own filter cartridges? Sheesh. Prior to cleaning, the pool was running fine, I had a bit of diminished suction at the skimmer for vacuuming, but that was to be expected because the filters were super clogged. I have a huge pine tree over my pool that dumps a mega ton of debris into it, and thus the filters are always badly clogged. They hadn't been cleaned since he did it last year. My whole goal in doing it myself was to be able to do it more often, keep things running a bit more smoothly, and save myself money in cartridge cleaning. And now this. Any suggestions? He said the only other thing I could do to test the system was remove the filters, put the lid on, and see if I still had the same problem as a test theory to see if the filter cartridges themselves were bad, but he said he seriously didn't think it had anything to do with the filter at all......even though that's the only thing about this scenario that is different, that this year I did the filters myself. And now a big clog? He said it could be a rock or could be anything in the line, but he didn't know how or why whatever I did could have created the clog. Before calling the contractor who charges $75 just to come out and look, any suggestions? Thanks!
- You may not post replies
- You may not edit your posts
Forum Rules
