Results 1 to 3 of 3
Thread: Well water
    Default Well water
    I just had my Walmart above ground pool filled today. The company didn't bring enough water (that always seems to happen) so I had to fill the rest with our WV (very hard) well water. I only had to add about 15% well water. Once I added the chlorine (please don't ask how much ) the water turned green by the time I was back in the house. How can I get it clear again? This is our second year and I am still clueless. Thanks!
    poolbuoy is offline Registered+ Thread Analyst poolbuoy 0
    sturbridge,mass.
    Default Re: Well water
    everyone can chime in but I use Metal out, try a qt. of the concentrate or a gallon of the non. keep filtering. oh yea check your CL and make sure it's not algae bloom.
    mbar's Avatar
    mbar is offline Lifetime Member Whizbang Spinner mbar 3 stars mbar 3 stars mbar 3 stars mbar 3 stars
    Ashland, PA
    It sounds like there is some metal in your well water. You didn't post any numbers, but to keep the metal in the water and not on the surface of the pool, you will have to use a sequestering agent like metal out, or Jack's Magic, metal free, sequasol, anything that will hold the metals in suspension. Keep your filter running 24/7 till the green goes away, and don't shock the pool till you add the sequestering agent. When you add water from your well, you should put the hose in the skimmer so it goes through the filter first. If you have a DE or sand filter you can put a trichlor puck in the skimmer when you are filling too.
    Northeast PA
    16'x32' kidney 16K gal IG fiberglass pool; Bleach; Hayward 200lb sand filter; Hayward pump; 24hrs; Pf200; well; summer: none; winter: mesh; ; PF:7.5
