Thread: Well water
    poolbuoy is offline Registered+ Thread Analyst poolbuoy 0
    sturbridge,mass.
    Default Re: Well water
    everyone can chime in but I use Metal out, try a qt. of the concentrate or a gallon of the non. keep filtering. oh yea check your CL and make sure it's not algae bloom.
    mbar's Avatar
    Ashland, PA
    It sounds like there is some metal in your well water. You didn't post any numbers, but to keep the metal in the water and not on the surface of the pool, you will have to use a sequestering agent like metal out, or Jack's Magic, metal free, sequasol, anything that will hold the metals in suspension. Keep your filter running 24/7 till the green goes away, and don't shock the pool till you add the sequestering agent. When you add water from your well, you should put the hose in the skimmer so it goes through the filter first. If you have a DE or sand filter you can put a trichlor puck in the skimmer when you are filling too.
    Northeast PA
