Thread: How do I correctly prime a well with a pool pump?
    May 2014
    South Florida
    Unhappy How do I correctly prime a well with a pool pump?
    Hi all,
    I would like to test the water in my well but I'm having a very difficult time trying to prime my pump with the well.
    The pump works well with my pool but when I physically hook up the pump to the well it just doesn't work. When we purchased the house, we were told the pool had been recently filled with the well water so I'm assuming the well is still functional.
    Any tips on what I should be doing or what I'm doing wrong?
    mas985's Avatar
    Pleasanton, CA
    Default Re: How do I correctly prime a well with a pool pump?
    How deep is the well?
    What pump are you trying to use?
    Only an in-ground pool pump will prime with the pump well above the water line and that is usually limited to about 8' or so.
    Mark
    May 2014
    South Florida
    Thanks for the reply mas985!
    I'm using the pools in-ground pool pump (1.5HP single speed).
    Unfortunately I have no clue how deep the well is though, but I'm pretty sure it's deeper than 8'. I believe an average well in this area (of course it all depends on who did it) is about 50' or so. So that's probably the problem I'm having.
    What is the correct pump to use if the well is 25-100' deep?
    mas985's Avatar
    Pleasanton, CA
    A deep well (submersible) pump is the only thing that will pump water that high. It is theoretically impossible to suction lift water more than about 34' but practically, it is much less that (~25'). So the only way to do this is to put the pump at the bottom of the well and push the water up with a high head pump.
    Mark
  1. Pool pump won't prime
    By jeffw in forum Pool Equipment & Operations
    Last Post: 05-21-2014, 07:59 PM
  2. Did I wire this correctly? just changed out my pump....
    By supercanadian in forum Pool Equipment & Operations
    Last Post: 05-08-2014, 01:33 AM
  3. Aqua Comfort S125 Heat Pump Not reading Water Temp Correctly
    By ghostcat in forum Pool Equipment & Operations
    Last Post: 07-20-2012, 11:12 PM
