Hi,
Just opened my 30k gallon pool a week ago.
Some background info:
Pool has a sand filter and sand was replaced last year.
Pool is around heavy tree coverage and due to early snowfall last winter (MN) it was well covered with oak leafs which were removed in spring when the snow finally disappeared.
When cover was removed water was black. But I am sure it was the main reason for the black pool water as the year before it was clear with some debris on the bottom of the pool.
I used around 5 gallons of liquid bleach to shock and after a couple of days of filtering and back washing pool is now green (can hardly see bottom in shallow end) but it seems to be better than before.
My numbers for 5/29 were (Done with LaMotta Color Q):
FC 1.92
PH 7.1
TA 163
CH 190
CYA 9
Added that day 8.5 lbs of Soda Ash to increase PH.
My numbers for 5/30 are:
FC 2.46
PH 7.3
TA 209
CH 185
CYA 2
Now I think (here I could use advise), to add more Soda Ash, 5.5lbs to continue to increase PH.
And do another round of liquid bleach (could use advise here on quantity).
My phone app (Pool Pal) which I am using, also recommends to add 159 fl.oz or 9.5lbs of dry stabilizer.
I have been brushing on a daily basis. A small kleen cleaner robot is cleaning but the hoover bag seems to get lined with algea which contains the water in the bag when removed from pool.
It looks like the sand filter is working over time and I am not sure if it's performing right as the skimmer baskets show minimal action.
When pool is set to circulate by passing the filter the skimmers work fine. I am planning to pull the filter apart to make sure it not a clumpy mess.
Thanks,
Ernst
