Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 36
Thread: Green Pool (Was black at first)
    May 2014
    Minnesota
    Default Re: Green Pool (Was black at first)
    Hi Doc,
    Thanks again.
    This AM when I posted my Color Q FC numbers I did do a FC measurement with my OTO kit and that one also looked like it was bleached out too (hardly any yellow). Now you state in your post that it should not bleach out.
    Makes me wonder that my FC Color Q measurement might be accurate after all (or am I confused). Pool does have a Chlorine odor.
    I am using the 12.5% bleach.
    30k gal IG vinyl pool, Hayward S200 filter, Pentair 2HP SuperFlo, 24hr ops. PF=4
    OTO is not super accurate, but it is super reliable. If it shows no chlorine, there's no chlorine.
    May 2014
    Minnesota
    Submitted my 6/6 numbers in the online spreadsheet. Still doing the evening 10 gallons of Chlorine and brush job. I am currently not filtering (only using vacuum robot) as I think the aerating will help at this moment. When brushing I have no more heavy clouds of dead algae.
    It seems water color seems slightly better but still a teal green and bottom only visible on shallow end.
    Sounds good.
    I noticed on your pool report that the bleach was 12%. Fresh 12% bleach will add a full pound of chlorine (Cl2 gas equivalent) to your pool -- 10 gallons would be 40 ppm of chlorine. When I was cleaning up big commercial swamps, I'd usually dump the equivalent of 100 ppm into a pool all at once. I don't recall that doing so ever failed to 'turn' the pool within hours. You've added at least 160 ppm, though over several days.
    I'm wondering if you have a bunch of ammonia in your pool. CYA is biodegraded by swamp slime (algae + bacteria). It can end up as harmless nitrogen, but it sometimes ends up as ammonia, and requires HUGE amounts of chlorine to clear. Do you remember what your CYA level was last fall?
    May 2014
    Minnesota
    Unfortunately I have no record or recollection of my CYA of last fall. One of the reasons I am now starting to record it all to eliminate guess work (second year pool owner).
    I did submit my tonight's numbers (Yesterday did the usual 10 gallon Liquid Chlorine and brush job).
    Finally FC seems to hold at a higher number, Used K2006 kit to measure 12 ppm as ColorQ as expected reported hi for reading (limit 10 ppm unless using workaround). Also used K2006 for ALY measurement which was similar to ColorQ.
    CYA measurement done with ColorQ as K2006 didn't yield any noticeable measurement which might be user error as was first try. After mixing 7ml of pool water and 7ml of the agent and mixing for 30 seconds the mix was clear and not obstructing view to the black dot in the tube.
    Can now see vacuum at bottom of pool and it looks like the chlorine is starting to do something. Not sure why it now starts to do it's job. We had rain and thunderstorms last night and during the day and this added 2" water to pool. I am aerating non stop and not filtering.
    Didn't have a lot of time tonight. Added 2 gallons of liquid chlorine and did a very quick brush job. I did read about the CYA potentially being biodegraded. Not sure if tonight's measurements are an indication or of any help.
    Thanks again.
  6. #16
    Quote Originally Posted by like2ct View Post
    Actually, the K2006 gave you a definitive measurement: ZERO. You have NO CYA.
    If you have access to a Sams Club, you need to get dichlor from them, and chlorinate with that: for every 10 ppm of chlorine added with dichlor, you get 9 ppm of stabilizer. http://pool9.net/sams-dichlor24/
    Otherwise, you can check Lowes, Home Depot, or Ace Hardware for dichlor showing 56% available chlorine (NOT: 56% dichlor!). Most of the dichlor sold today is diluted.
    Until you have some CYA in your pool, the only meaningful measurement of chlorine loss is from late evening to early morning: daytime loss under full sun would be expected to complete, regardless of chlorine level.
  7. #17
    May 2014
    Minnesota
    Updated my numbers for today.
    Have 50lbs of the Dichlor with the 56% available chlorine. Not entirely sure how much to add though. Do I build it up slowly?
    Used some pool calculators and it looks like 9oz yields around 1 PPM of FC and 0.9 CYA. Looks my goal is 40 CYA.
    Will start with 72oz as it's easier to add as I think that I need a lot more. Current FC is 8.28.
  8. #18
    Yes, slowly.
    Basically, simply use it to chlorinate, till your CYA is at your target level.
    You'll find that initially (while CYA is low) you'll lose chlorine quickly. But as the CYA increases, chlorine levels will be more persistent.
  9. #19
    May 2014
    Minnesota
    Added today's numbers. Didn't measure CYA as I understand below 30 no way to measure with my tools, my best guess based on FC level is around 9 as my FC went from 8 to 18 ppm (Had overcast and no sun).
    Will add another 72oz of dichlor. Water still light green. Can see bottom. Not filtering just circulating and aerating.
  10. #20
    Until your CYA is higher, add your large doses late in the day, so they can work all night before being hit by sun.
  1. Small Black dots in salt pool. Black algae?
    By jeanne3434 in forum Dealing with Algae & Slime
    Last Post: 04-06-2014, 05:58 PM
  2. New house with a black pool
    By wleveille in forum Dealing with Algae & Slime
    Last Post: 05-31-2011, 10:09 PM
  3. green pool: like black/green pool
    By bazman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-06-2010, 11:25 AM
  4. Help!!! My water is Black and liner looks black & burned
    By Gwendolyn in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-29-2007, 10:41 PM
  5. Black Pool Water
    By pminct in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 04-27-2007, 12:10 PM
