Thread: Lower PH?
    Sanford, FL
    Default Re: Lower PH?
    Add the acid in small doses - let circulate for about an hour and test again. Use protective gear when using it - like gloves, eye protection, and don't inhale it - I think I burned off all my nose hairs the first time I opened a bottle
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    sailork is offline Registered+ Thread Analyst sailork 0
    Houston (Clear Lake area), TX
    If you download mwsmith2's BleachCalc it will compute how much acid to add.
    http://home.earthlink.net/%7Emwsmith...achCalc262.exe
    22,000 gal gunite pool, 1.5 hp pump, DE filter, and dreams of a SWG.
    Cleveland, OH
    Wow thats some powerful stuff. Where can I get the acid?
    Indiana.
    Quote Originally Posted by MaxxFusion
    Hardware store, Lowe's etc.. Paint department or concrete section.
    Sometimes it's actully cheaper at the pool store. check for prices. and make sure you have REAL muratic acid. some places are now selling a muriatic acid substitute!
