Thread: Pump PSI Issue. Need Help
    May 2014
    Default Pump PSI Issue. Need Help
    I recently cleaned out my DE filter and now when I start my pump the PSI is good at around 14-15, but after about 5 minutes it jumps to about 20 and I lose pressure. Can anyone help?
    May 2014
    Default Re: Pump PSI Issue. Need Help
    I just took the cover off my pool a few weeks ago and there was some algae that got into the pool. I was hoping to just vacuum it up. I do see some algae at the bottom of the pool on the deep end. How would I know for sure?
    It would be green and your water may be cloudy depending on how bad the algae is. Sounds like if you do have algae, it is minimal.
    Do you have a test kit? If so, what kind?
    BigDave's Avatar
    Is there a way to bypass the filter - maybe recirculate? A DE filter will clog quick with live algae. Get adequate chlorine in before the algae is not minimal.
