Results 1 to 10 of 45
Thread: Dealing with scale problem
    May 2014
    Sussex, WI
    Default Re: Normal PH, TA off the charts
    Hi Watermom. I'm assuming that stabilizer levels in the chart and CYA are the same thing? My test kit gives me a chlorine level over 5 ppm. My CYA is probably still low as I only added stabilizer on Saturday. Does that mean my "free chlorine" is low and therefore my chlorine is ineffective?
    stabilizer = "conditioner" (mostly in Calif) = cyanuric acid = isocyanuric acid = CYA = "CA" (some kit instructions => C.A., cyanuric acid) = etc.
    Why have just one name for a chemical, when you can have a half dozen?
    Did you look at the Best Guess Chlorine Chart in my signature above to understand the CYA (stabilizer) and chlorine connection?
    Your kit only has the capacity to measure to a chlorine reading of 5ppm which means you can't really tell what your chlorine is when it reads 5ppm. This is one of the main reasons we want people to order the K2006 as it can measure chlorine levels way higher than that.
    Assuming that your CYA is still low since it was just recently added, you need to get your chlorine level up to around 10-12 and try and hold it there in order to kill the algae. Since your kit won't read higher than 5, you kind of just have to judge based on the color. Take a look at the first post in the following thread. If you click on the link in that first post, it will give you a color matching to try and decipher what various OTO colors mean in terms of chlorine levels. (Your kit uses an OTO chlorine test.) Aim to keep yours in the very dark yellow/orange level.
    http://www.poolforum.com/pf2/showthr...sults-by-color
    May 2014
    Sussex, WI
    Hi again, Yes, I did look over the chlorine chart, and it makes sense. I'm not sure I understand the difference between the two "shock" columns. Looks like I need to get out to buy some more shock. Did I read in another forum that some people use regular unscented chlorine bleach instead of paying for shock? I'm assuming you need to use more due to the smaller amt of active ingredients.
    One question I have is about CYA levels is the relationship between CYA levels, total chlorine levels and free chlorine levels. When CYA levels are closer to "normal" is there less of a spread between total and free chlorine levels?
    Also, how long does stabilizer levels take to rise after addition to the pool?
    P.S. one more name for stabilizer - clarifier.
    Stabilizer is NOT the same thing as a clarifier. Clarifiers cause smaller particles to clump together so they can be filtered out more easily, however, we seldom suggest using them. Stabilizer, or CYA, is kind of like sunscreen for your chlorine. Without enough in the water, your chlorine is quickly lost to the sun.
    Regarding the two shock columns, you typically only need to shock as high as the first column unless you have a really resistant algae like maybe mustard algae. However, if you keep your chlorine at the proper levels, you never have to shock. Some pool stores will tell you that you need to shock weekly. That is not true. The only time you ever need to shock is if your chlorine levels drop too low or if you have a lot of organic debris in the pool. I seldom shock. I test my water almost daily and always maintain proper chemistry. When you do need to shock, you can just use bleach. We like to say that the word "shock" is a verb and not a pool product. You would just add a larger than normal dose of bleach to get to the shock level that you need based on the Best Guess chart. Make sense?
    FC + CC = TC. Always. Regardless of what your CYA levels are, the equation is always constant. Ideally, you want your CC to be zero which means that your free chlorine and your total chlorine would be the same.
    We may have already told you this but not sure. But, in your 25K gallon pool, each 121 oz. jug of 8.25% bleach will add about 3ppm of chlorine to your pool. Use that as a reference to help you figure out doses of bleach that you need to add to your pool.
    Hope this is all helping you better understand taking care of your pool chemistry.
    Where have you seen stabilizer called "clarifier" -- if someone in a pool store is calling it that, I'm pretty sure they are just confused.
    The relationship between CYA and chlorine is more a constant fraction, rather than a constant PPM. That is, under ideal circumstances, if your chlorine ppm is 5% of your CYA ppm, everything's good. On the other end, sometimes killing mustard algae takes a chlorine ppm that's 25% or more of your CYA level. The relationships are not all mathematically linear, so that's not perfectly true. For example, a chlorine level of zero is not going to help, even if your CYA is zero.
    But, it's approximately true.
    Finally -- your pool doesn't care how the chlorine gets there: chlorine gas, bleach (sodium hypochlorite), dichlor (sodium dichloro-isocyanuriate) all work. But if you use store bleach, get the PLAIN store brand 8% bleach, and not the 'flavored' bleach that Clorox has been marketing.
    May 2014
    Sussex, WI
    Hi, I have some clarifier that mentions longer chlorine life as a benefit. I wrongly assumed the similar benefit made it the same as stabilizer. I didn't use it anyway, so no harm. My CYA still is low a week after adding stabilizer. I added 4 more lbs today, which, according to the chart is supposed to raise it about 10ppm. I guess only time will tell. I tested PH and chlorine this morning. PH was 7.2 and chlorine was 5 ppm. I'm going to give the stabilizer a couple of days to work before adding any more chlorine. We're supposed to stay cool and cloudy over the next few days, so I think waiting will be ok although I will test daily. When my CYA looks better, I'll deal with the algae problem.
    If you stop adding chlorine, your algae will take over even more than it already is! You don't want that. You need to be adding chlorine daily up to shock levels! Don't stop and let the algae get even worse!
    May 2014
    Sussex, WI
    I'm so glad I read your posts about adding chlorine this morning. I was at 5 ppm this morning and added enough "shock" to bring it up to the shock level in Watermom's chart. (If my math was right I added 8 PPM with 2 gallons of 12% chlorine) The forecast was for mostly cloudy and cool so I thought I would not lose too much over the course of the day. As often happens, it was a gorgeous sunny day and most or all of what I added is gone. Using the color chart I'm somewhere between 6 and 9 ppm as of now. I added more immediately. The good news is I can see some progress with the algae.
    I should probably have mentioned that last year, we had a terrible problem with scale after "topping off" our water level in spring with hard water. Our iron filter had clogged and I had to bypass it. I thought I could deal with the consequences in the pool in time, but suddenly found myself working 90 or so hrs a week. To make a long story short, we spent most of the summer working to soften and remove it. Some of that scale is still on the liner and is giving the algae a great place to root itself.
    Lastly, I wish I had found this forum before I bought a large supply of shock. Our local Ace hardware always gives a good price on larger amounts in spring so I have always loaded up. It's a good price for "shock", but still more expensive than regular bleach.
    Thanks so much for the help. You can bet I'll be referring back to the forum often.
