Results 1 to 10 of 45
Thread: Dealing with scale problem
    Default Re: Dealing with scale problem
    Here's a rough color chart for high ranges with OTO: http://pool9.net/oto-chart/
    As far as I know, I'm the only one who has advocated using OTO this way; certainly I've never seen a pool kit with color block for the high range.
    I'll help where I can, but you have to understand: no matter what your budget is, your pool will NOT forgive you. And it will cost far, far more to clean up, than to avoid problems.
    I'm sure you really want to swim. But you might consider replacing the cover on your pool -- leaving 1/8 exposed, to 'breathe' the gases that form when chlorine breaks down goo. Covering the pool with hurt the algae and GREATLY reduce the chlorine need to eradicate it. That's the only way I know to deal with your situation AND cut expenditures significantly.
    You would be able to swim in the late evening, without increasing costs much IF you avoid lotion on the swimmers (chlorine demand) and pee (BIG chlorine demand). You could continue aeration that way, too. Just keep it covered when the sun is shining.
    Best wishes.
    May 2014
    Sussex, WI
    I'd rather leave covering the pool as an absolute last resort. To keep my cover on means having the brass bolts raised. Too great a risk of someone stubbing a toe. I am making progress. Maybe not as fast as I'd like, but as I keep at it and follow your advice on chlorine, oh, etc, the algae is slowly going away. My biggest concern is the scale. I think my current course of action is helping, but getting the strange reading from the hardness test concerns me. I'm still curious what a yellow color result when the hardness indicator is used means with the HTH kit.
    Quote Originally Posted by beaverplt View Post
    Then, you're losing.
    You are wasting chlorine, wasting time, wasting effort, and wasting money.
    Kill it quickly, as Watermom told you several days ago:
    If you stop adding chlorine, your algae will take over even more than it already is! You don't want that. You need to be adding chlorine daily up to shock levels! Don't stop and let the algae get even worse!
    Maybe, but you can't deal with the scale, till the algae is gone.
    You raised the issue of the cost of dealing with the algae. If cost is not that much of an issue, leave the cover off. If it is, cover it.
    I wasn't suggesting that you swim with the cover one. I was suggesting that you forgo swimming till you've solved your algae problem.
    The HTH 6-way has a different hardness test then the K2006. Here are the instructions: http://pool9.net/hth-6way/
    May 2014
    Sussex, WI
    Losing? How? Since Watermom told me several days ago to keep adding chlorine, I have kept my chlorine level in the orange color range of the OTO chart that she sent me. I'm checking it twice a day. The lowest it's gotten is dark yellow. That has been over a week now. During that time my PH has stayed at 7.2 and my TA near 110 until tonight when they were 7.5 and 150. Is it possible that the algae is dead, but so intertwined with the scale that removing it requires a lot of brushing? The algae is no longer green, rather kind of an ochre/light brown color.
    My HTH kit came with the same instructions you linked, so I have been following the correct procedure. The good news is when I tried it again tonight, it worked and I was able to get a hardness reading of 310. I wonder if the kit has a "floor" it won't give results below.
    Another little bit of good news is I saved a good piece of change when a lawn tractor repair I needed to do cost me almost nothing other than my labor and some good luck. I immediately ordered a K2006. I'll have it Thursday. I'll keep testing with the HTH until then, but I'll share my new test results Thursday night.
    OK. I hadn't understood that. I thought you were saying there was still green algae.
    Brown algae is dead. And yes, when the calcium 'sand' is present, the algae will remain brown inside those nodules till it's bleached out by sun and/or chlorine.
    There probably IS some live algae inside some of the bits, but if everything you can see is brown, then you can move own. So do this:
    1. Use muriatic acid to lower your pH to just below 7.0. That is, add acid till you reach 7.0, and the add a bit more. Read http://pool9.net/muriatic/
    2. Dose with chlorine nightly, to maintain chlorine levels above 5 in the AM.
    3. Brush the scale after adding chlorine, if you can. Don't brush hard, just enough to knock loose what's already coming loose.
    4. Complete the pool chart: http://pool9.net/pf-chart/ so we can see what sort of pool you have.
    5. Increase aeration by adjusting the return eyeballs to 'riffle' the surface.
    May 2014
    Sussex, WI
    OK. I hadn't understood that. I thought you were saying there was still green algae. My fault, I should have mentioned the color earlier
    I added a half gallon just now. I'll check PH before bedtime to see if more is needed.
    2. Dose with chlorine nightly, to maintain chlorine levels above 5 in the AM. I'm at dark yellow or about 13 ppm on the oto chart right now. I was in the orange range this morning and most of the day was cloudy. It seems I lost more chlorine today than I have over the past 3 days. Is that due to the higher PH?
    3. Brush the scale after adding chlorine, if you can. Don't brush hard, just enough to knock loose what's already coming loose. Easy enough, between my wife and I we've been brushing twice daily plus running our cleaner almost all day.
    4. Complete the pool chart: http://pool9.net/pf-chart/ so we can see what sort of pool you have. Stupid of me, should have done that when I joined.
    5. Increase aeration by adjusting the return eyeballs to 'riffle' the surface. My eyeballs that are in my steps are a good 6-8 inches below the surface. I aimed them as high as I can. I can see minor riffling when I do. My other return riffles the surface nicely when turned slightly up Question; doesn't aeration increase PH? Am I negating some of the effects of adding muriatic acid?
    One more thing. I had almost forgotten that we are going out of town this weekend to celebrate our son's birthday. That means two days without attention. I don't want to lose ground. Any suggestions?
    Thanks for your help.
    25k gal pool, 18 x 36, 3' to 8' depth. Vinyl lined. Single speed pump
    Aeration strips carbon dioxide, which raises pH. But aeration LOWERS 'carbonics' => carbon dioxide + carbonic acid + bicarbonate + carbonates.
    Essentially, alkalinity is that fraction of the 'carbonics' that is present as bicarbonates or carbonates. You can't easily remove those. BUT if you lower the pH, you shift some of the bicarbonates and carbonates into the form of carbonic acid + carbon dioxide.
    In your case, reducing the alkalinity enable your pool water to begin dissolving the scale. But that, in turn, replenishes the alkalinity, and increases the calcium.
    Since you're leaving for a few days, I'd re-orient the eyeballs to reduce aeration, let the pH drift up to a stable plateau, raise the chlorine level -- and then restart the process once you return.
    Brushing 2x per day probably doesn't hurt anything, but it probably doesn't help that much, either. Once a day, or even once every 2 days is probably enough. It's unlikely the dissolution process is moving fast enough to warrant a 2x per day brushing.
    Losing chlorine could be a result of dissolving some of the algae capsules, and exposing oxidizable algae to the chlorine.
    I'll look at your chart data, and update your pool sig. info.
    Just checked -- there is no chart entry for "beaverplt", nor any entry associated with this thread (24064)
