Re: Pool cooling
Evaporative cooling should work if the air is dry, better if the air is dry, cool and breezy. What's the weather like at night? I can't say if half a dozen jet spray arc fountains will do it. Are those the laminar flow arcs? If so, they probably don't add much surface area for evaporation. Better a spray that divides the flow into many tiny streams / drops.
Is water expensive? Evaporative cooling will consume makeup water. There are heat pumps that can cool the water if electricity is cheap for you.
