Results 1 to 10 of 21
Thread: Pool Pilot Digital 220 unit - Warning Low Amps - Cell? and Bad Temp Sense
    Jun 2014
    Tennessee
    Default Pool Pilot Digital 220 unit - Warning Low Amps - Cell? and Bad Temp Sense
    I have had this unit for 5 years and this is the second SC-48 cell for the unit. The first cell was bad (not getting an chlorine) after the first season and was replaced by the local dealer where I purchased the system. This latest issue started at the end of last season just before I closed the pool for the winter.
    The display is reading 28V, 1.4 A (was 28V, 1.7 A last week) and the unit is not producing chlorine, test results below.
    I have checked the three fuses, removed them and tested for continuity with a multimeter, all three good.
    I have checked all pins in both cables from end to end for continuity and each is good.
    Visual inspection of all internal components didn't reveal any signs of burnt wires, popped capacitors, or burnt board components. All connectors reseated. Both fans operating and I can hear the unit click on and off when put in BOOST mode, just as it always has
    20'x40', 3' to 8' in ground grecian shaped pool, 28,000 gal, 4 returns, main drain and skimmer, sand filter (new this year - replaced DE filter)
    Cell = SC-48
    Software Ver 4.2
    Power Level = 3 (I just bumped this up last week to see if it made a difference, having been running at power level 2 last three years without issue)
    Salt 3400 (pool store tested at 3300)
    Actual water temp is at 84 degrees but unit is reporting 75 (again, Bad Temp Sense is one of my issues)
    Calcium Hardness = 200
    Cyanuric Acid = 0
    Total Alkalinity = 100
    pH = 7.6
    Copper = 0
    Iron = 0
    Phosphates = 0
    I had just cleaned the cell prior to the start of this season, have never had an issue with scale or build-up but did the recommended cleaning anyway. Also cleaned the temp sensor at the same time as my local pool store said that the temp sensor didn't "appear" to be bad. They normaly see signs of the two temperature pickup points being burnt on a bad sensor and they said mine looked fine, recommended cleaning it and trying it again, no change though.
    Any thoughts? I don't want to spring for a new cell if there is something wrong with a board or another issue.
    Default Re: Pool Pilot Digital 220 unit - Warning Low Amps - Cell? and Bad Temp Sense
    . . . membership upgraded.
    If you'll look at the bottom of the page, there are a number of threads reporting similar problems. If none are relevant, post again, and I'll ask PoolSean to take a look.
    Jun 2014
    Tennessee
    Thanks for the info. Looks like thread 23752, the first one in the list is my exact problem. Didn't clean the ends of the fuses so will try that and hope that I get the same results.
    Thanks for your time in creating and managing this site, very helpful.
    28k gal 20'x40' grecian-shaped vinyl IG pool, 4 returns, main drain & skimmer, Waterway 22" sand filter (new this year - replaced DE filter)
    Jun 2014
    Tennessee
    Well, that didn't solve my iussue, no joy here. Cleaned all three of the fuses and still getting the same readings. Also checked the other connections and no corrosion on any of them.
    Let me make sure I understand:
    1. The cell has been in service for 4 years.
    2. The only fault is lack of chlorine production.
    3. You have occasional, or regularly, used the BOOST mode.
    Is that all correct?
    If so, is there reason you aren't thinking that the cell is simply at the end of its life? Are you aware that SWCG cell life is pretty much a straight forward function of "ON" time? And that BOOST mode results in significantly reduced cell life?
    Jun 2014
    Tennessee
    Yes, all is correct. Last year due to the conditions in our area we did use boost more frequetly than in the prior years. I am aware that the life of the cell is limited but wasn't sure how many years I should expect to get from normal use. Having looked around on the internet for others with the same issue, and finding all sorts of reason that the unit may not be functioning, I didn't want to just order up a cell without exploring/investigating all the possibilities.
    I also have a church friend whose neighbor uses the same system and was getting similar (not sure if it was exact) messages and it turned out he had three bad diodes on a control board. Once he had the board repaired all was well. Again, I dont know if he had any Voltage or Amperage reading, just that he had the same warning message.
    It does appear that my issue may just simply be the cell is at end of life and I need a new one. Just trying to cover all the bases.
    So your recommendation would be to purchase a replacement cell? Appreciate your time and feedback.
  1. Digital Pool Pilot Low Amps Reading Solved (Hint - No New Cell Needed)
    By ghanner in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-25-2014, 01:59 PM
  2. Pool Pilot Digital. Low Amps check cell?
    By Bobdog in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-08-2014, 12:44 PM
  3. Pool Pilot Low Amps Cell 0V 0.6A
    By vgg659 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-22-2011, 02:07 PM
