By the way, what is your wall height on your pool? I think you may be overestimating the volume of your pool. I'm assuming it is 54" (same as mine) which means your water level is around 50 inches. This puts your volume at more like 18K gallons. I was trying to determine how much chlorine a gallon of 12.5% bleach would add to your pool (assuming it is that strength) and need an accurate volume to do so.
R- I have a deep end that is about 5 1/2', sometimes deeper when the water runs high after it rains a lot.
