Results 1 to 10 of 14
Thread: starting over
    Jun 2014
    central New Mexico
    Default Re: starting over
    I only wanted to raise it slightly, so it is now 7.5.Today I noticed the water is slightly cloudy ,but with it being new water will this clear up or is it something else ph is 7.5 and cl was 8 last night. tonight I not ad more bleach if it is till up there or should I any way?
    20 x 52 intex above ground, intex 1650 gph sand filter with a salt ozone
    7.5 is fine.
    No idea about cloudiness -- what is your chlorine level?
    Even a brief period with low chlorine will result in cloudiness, ESPECIALLY if the pool is being used.
    Jun 2014
    central New Mexico
    cl is at 5 tonight i guess it wasn't cloudiness just not sparkling water, it is getting better.Now it appears I may have a leak some where any tips on finding them ?
    As they say, "if it wasn't for bad luck, you'd have no luck atall!"
    With an AG pool, the obvious first step is to go over the outside of the pool carefully. Once you've eliminate the bits you can see, all that's left is the floor!
    Unfortunately, that's harder. You almost have to have SCUBA: the process of diving down stirs the water so much that you can't follow the dye currents. Here's a video of me leak checking a skimmer throat (pump off, of course): https://www.youtube.com/watch?v=Y90c7pYMgPc
    Jun 2014
    central New Mexico
    cant post any where but here/ So next year we are thinking a bigger pool /
    How big is our 3/4 horse sand filter good for?
    Maybe 15,000 gallon, max.
    Jun 2014
    central New Mexico
    Is that maybe to be safe, or GOOD GUESS. I still cant post anywhere but here?
