Results 1 to 3 of 3
Thread: not cleaning pool
    Apr 2014
    S. Central Illinois
    Default not cleaning pool
    Hi I am a newbie to this sight and had a question, when I opened my pool this year and tried to vacuum it it did not seem to have enough suction to even keep the hose in place on the skimmer, I tried it on waste and also filter. I changed the sand and still did not help, it seems my return does not have the pressure it use to. Not sure where to start????
    Default Re: not cleaning pool
    Unfortunately, low flow / low suction is one of those pool problems with many possible causes. Here are a few:
    + Air leak in suction piping, weakening pump's suction.
    + Clogged impeller (pebbles, pine needles, etc.)
    + Clogged or damaged strainer basket.
    + Kinked suction piping.
    + Damaged or failed valve that looks open, but isn't. (Both ball and gate valve stems can break)
    Apr 2014
    S. Central Illinois
    Thank you that gives me some places to start looking
  1. Pool Filter Beyond Cleaning?
    By GTSpecial in forum Pool Equipment & Operations
    Last Post: 08-14-2012, 03:45 PM
  2. cleaning the snow around pool
    By ArtCan in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 01-17-2012, 09:02 PM
  3. Unluck with Pool Cleaning
    By Twinkie in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-21-2011, 11:10 PM
  4. Cleaning the deck around the pool
    By JonnyG in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-11-2006, 10:49 PM
