Re: Filter problem
The water isn't green anymore but it's still cloudy. Do you think I need to clean those fingers with acid?
Re: Filter problem
Sounds like you may have a Perflex:
https://www.hayward-pool.com/pdf/man...rflex-EC40.pdf
Read the manual; do what it says. Do NOT clean with acid unless you have first cleaned with detergent. Cleaning with acid first reportedly can 'set' grease and oil, and make it un-removable.
