Results 1 to 10 of 13
Thread: Cal Hypo question
    jnorris is offline Registered+ Thread Analyst jnorris 0
    Florence, SC
    Default Re: Cal Hypo question
    Here's my latest test:
    FC 2.0 ( I know, it's low!)
    TC 2.0
    PH 8.0 (was 8.2, added dry acid, but apparently didn't add enough)
    TA 110
    CYA 40
    Don't know about calcium level.
    This is a new vinyl pool, just filled 4 weeks ago. Haven't shocked yet. Pool builder gave me a BIG TUB of cal-hypo (consolation prize for the pool leaking half the water out in the first week!), it is 68% strength.
    I am going to get muriatic acid tonight. I have a little mustard algae. I am using the trichlor sticks right now. Will probably stop that in a week or so, but I will use those when I go out of town (which is alot). I don't have anyone who can add pool chemicals for me while I'm gone, so I will use the sticks for that, but am planning to switch to bleach soon. I just thought I'd use the cal-hypo to shock since I have it. I know it can make the water cloudy if my calcium is too high, but I don't have a test for it. I guess I could have it tested at a pool store. But I thought I'd go ahead and shock it once with the cal-hypo and see what it did. I just really don't want to be buying 8 or 10 3 qt bleach bottles at a time to shock if I don't have to.
    So, my original question, how do I know how many of those scoops that are in the tub I use? Like I said, it looks like it would hold about 8 ounces of liquid, but I know that doesn't measure weight, and when the package says to add a certain number of ounces, it probably means by weight, doesn't it?
    Thanks,
    Judy
    Quote Originally Posted by jnorris
    TC 2.0
    TA 110
    CYA 40
    Thanks,
    Judy
    First off. Stop using the tri-chlor sticks. Your CYA is 40, and if you use them while out of town it will go up. That's ok if you have room, and you do, but if you use them when you aren't going away, the CYA will STILL go up.
    FC is a little low--CYA=40 means you should never let FC go below 3ppm and shock by going to 15ppm.
    More importantly you MUST get your pH down. With a pH of 8, a CYA of 40 and an FC of 2, you have the equivalent of NO chlorine in your pool. As pH goes down, chlorine effectiveness goes up. So you need to add muriatic acid to get it down to 7.3-7.8--but aim for 7.4-7.6.
    68% cal-hypo is the good stuff. If your CH level is nice and low, feel free to use it to chlorinate instead of the sticks. Vinyl pools can tolerate calcium levels from 0 to 500ppm.
    So: Get the pH down, use the Cal-Hypo to get the FC up, and stop using Tri-Chlor sticks, saving them for when you travel.
    Florence, SC
    Quote Originally Posted by CarlD
    Aye Aye Captain! One more thing, I need to make sure that there are no Trichlor sticks in the chlorinator before I add the cal hypo, right? Or can I just turn the chlorinator dial to zero, but leave the sticks in there? Is there a waiting period before I can add the cal hypo, or just add it after the sticks are out?
    Thanks so much for the help. You people are the best!
    Judy
    Not to worry! I'd add the cal-hypo by dissolving it first in a 5 gal bucket then pouring the solution in front of the return.
    As long as the cal-hypo crystals don't touch the Tri-Chor stick you are fine--dissolved in the water, chlorine is chlorine. So you can add it immediately, even before removing the tri-chlor sticks from their feeder.
    If it were me, I'd take the sticks out completely and save them for the travel time.
  1. Cal Hypo
    By Rickmart in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-06-2012, 10:58 AM
  2. difference between cal hypo and sodium hypo (from bleach)
    By kasatpoolforum in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-20-2010, 08:12 PM
  3. cal hypo and ph
    By john509 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-16-2010, 05:59 PM
  4. 65% Cal Hypo
    By Sherra in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-12-2006, 02:02 PM
  5. Bleach vs Cal Hypo.
    By houston in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-24-2006, 08:38 AM
