jnorris
Here's my latest test:
FC 2.0 ( I know, it's low!)
TC 2.0
PH 8.0 (was 8.2, added dry acid, but apparently didn't add enough)
TA 110
CYA 40
Don't know about calcium level.
This is a new vinyl pool, just filled 4 weeks ago. Haven't shocked yet. Pool builder gave me a BIG TUB of cal-hypo (consolation prize for the pool leaking half the water out in the first week!), it is 68% strength.
I am going to get muriatic acid tonight. I have a little mustard algae. I am using the trichlor sticks right now. Will probably stop that in a week or so, but I will use those when I go out of town (which is alot). I don't have anyone who can add pool chemicals for me while I'm gone, so I will use the sticks for that, but am planning to switch to bleach soon. I just thought I'd use the cal-hypo to shock since I have it. I know it can make the water cloudy if my calcium is too high, but I don't have a test for it. I guess I could have it tested at a pool store. But I thought I'd go ahead and shock it once with the cal-hypo and see what it did. I just really don't want to be buying 8 or 10 3 qt bleach bottles at a time to shock if I don't have to.
So, my original question, how do I know how many of those scoops that are in the tub I use? Like I said, it looks like it would hold about 8 ounces of liquid, but I know that doesn't measure weight, and when the package says to add a certain number of ounces, it probably means by weight, doesn't it?
Thanks,
Judy
