Results 1 to 9 of 9
Thread: Will TSP to lower calcium hardness???
    Default Re: Will TSP to lower calcium hardness???
    There are calcium reducers that are sequesterants but have more of an affinity for calcium than other metals. They are based on derivatives of phosphonic acid (as are most of the metal sequesterants) TSP will raise your phosphate levels very high and can provide a lot of algae food. The phosphonic acid derivatives don't seem to do that as much but they can still raise the phosphate levels from what I understand.
    waterbear,
    Can you provide some product names for those calcium reducing products ? My fill water has about 350-400ppm calcium. This is the 3rd year for the water and with all the evaporation we experience in the Vegas area the CH is over 1000ppm. I am thinking about emptying the pool at the end of this season but if I can reduce calcium before that I might be able to alleviate some of the scaling before then.
    check with your pool store or online seach for calcium hardness reducer. You want a product that is a derivative of phosphonic acid. Many metal sequesterants will also reduce calcium. Read the bottles and see. If you can read the MSDS. That will usualy list phosphonic acid as a component.
