Thread: HP6002 Heat Pump - High Pressure
    Jun 2014
    Quebec
    Default HP6002 Heat Pump - High Pressure
    Hello,
    I started the heat pump today and it turned on for 5 seconds and shut off with the diagnostic code HP (high pressure) I'm a bit stumped as to what it could be as one issue could be low water pressure.
    Currently my filter is reading 15PSI so it seems quite clean, would you suggest to disconnect the pipes going to the heat pump to check for sufficient water flow?
    Thanks!
    Default Re: HP6002 Heat Pump - High Pressure
    You'll need to provide exact make / model info, in order to have a chance of getting some useful responses.
    Is that what is in the title of his thread or do you need more than that?
    May 2014
    Plano, TX
    Have you had the unit serviced recently? Overcharging can cause this. The fact that it's kicking out in 5 seconds kind of leads me to believe what you have is a pressure switch failure.
    On any heat pump, the most common cause of high pressure is debris clogging the condenser. On a pool heat pump it may be called something else. Can you backwash, or reverse the flow through the heat pump? Have you had a filter failure that would allow gunk to get to it? Scale build-up will also reduce heat transfer, but wouldn't happen suddenly. It would start out by running several minutes, then cycling off and coming back on in a minute or two.
    It may be a Hayward HeatPro, but I'm not sure.
  1. Pressure too High!
    By auntphibian in forum Pool Equipment & Operations
    Last Post: 05-07-2014, 03:46 PM
  2. Very high pressure HELP!!
    By ALGESIDE in forum Pool Equipment & Operations
    Last Post: 07-09-2011, 10:37 AM
  3. pressure too high
    By joe49er4 in forum Pool Equipment & Operations
    Last Post: 09-03-2010, 10:58 PM
  4. DE Filter pressure rising high, no water in pump
    By fog80 in forum Pool Equipment & Operations
    Last Post: 07-01-2010, 07:22 PM
  5. Leaving Pump On With High Pressure
    By NullQwerty in forum Pool Equipment & Operations
    Last Post: 05-25-2006, 02:04 PM
