You probably want a total of about 8 or so hours per day. I'm not the pump expert on the forum, but I would think multiple starts and stops day after day would be less than ideal for the pump.
Even though you are using BBB, the turnover is for more than just skimming; it also mixes in your chemicals and keeps your pool from having dead spots which could make algae more likely in those areas.
