Results 1 to 10 of 20
Thread: New here
    Default Re: New here
    Soda ash raises pH and TA. Borax raise pH without affecting TA much which is why we prefer it to soda ash.
    Jun 2014
    Cool. I guess all the reading up I'm doing is finally sinking in (no pun intended).
    btw, what does the "PF=6" that was added to my signature mean?
    19.5k gal, 16x32 vinyl liner, sand filter, 1hp single speed pump, K-2006 test kit. PF=6
    PF stands for "Pool Factor" which is a calculation that Pooldoc uses to estimate effects on water with given amounts of chemicals. Here is something I copied and pasted from another post Ben wrote that may help you better understand how it works:
    PF = pool factor.
    If you add 1 lb of chlorine gas to a pool with a PF of 1 (120,000 gallons = 1,000,000 lbs) you get 1 ppm of chlorine.
    If you add 1 lb of chlorine gas (100% chlorine) to a pool with a PF of 10, you get 10 ppm of chlorine.
    If you add 1 lb of dichlor (55% chlorine) to a pool with a PF of 10, you get a 5.5 ppm of chlorine (1 x 10 x 0.55)
    Jun 2014
    Thanks for the explanation. Gee, and I thought I just had cool factor
    Quote Originally Posted by Big Splash View Post
    You do, Big Splash, you do!
