Results 1 to 10 of 10
Thread: New to forum and pools!
    Jun 2014
    New york
    Default Re: New to forum and pools!
    Fc up to 7.2 and ph down slightly to 7.2 (as a result of the cya I assume) will wait a few days to test cya level but added a bit more today and my best guess is that I should be around 45 after all is said and done. Chlorine held well added last night and while today was mostly cloudy it seems as if the chlorine is beginning to hold. Will add some borax tomorrow to keep ph in the 7.6 region. Looks like I may be swimming this weekend!
    Quote Originally Posted by Giants85 View Post
    Awesome! That would be great. I intend to get off this computer and do the same! I gotta enjoy my pool, too!
    if you will use a 10mL water sample when you do your chlorine tests instead of the 25mL sample, you will save on your reagents. It gives you a reading to the nearest 0.5 instead of 0.2 but that is plenty good enough.
    Keep up the good work!
    Jun 2014
    New york
    Thanks ill do that from now on. Can't emphasize enough how helpful this site has been.
    We are glad to be here and able to help. Let us know if you have further questions.
