Results 1 to 10 of 12
Thread: K-2006 Arrived! Results Within
Threaded View
  1. #2
    May 2014
    Plano, TX
    Default Re: K-2006 Arrived! Results Within
    Bleach first! Get up to about 3ppm at sundown (or when the sun is not shining on the pool). pH is next, add a box of 20 Mule Team Borax ASAP. Less than 7 might mean 3. Low pH can damage your pool. Dose with borax, wait 2 hrs, test, redose, repeat, till pH is ABOVE 7.
    Also, it looks like you are using 25ml samples rather than10ml. Each drop in a 25 ml sample is .2ppm. Each drop in a 10 mil sample = .5ppm. 10ml samples are plenty accurate for the purpose of maintaining your pool.
    Enjoy your pool!
