Results 1 to 10 of 12
Thread: K-2006 Arrived! Results Within
    Default Re: K-2006 Arrived! Results Within
    If it doesn't turn pink with two scoops, stop adding powder. It means you don't have chlorine. (Also, if it turns pink with one scoop of powder, you don't have to add the second one.)
    Wait 3 or 4 hours before retesting to let it circulate well.
    May 2014
    Texas
    Tested it again this morning - didnt turn pink. Put in another jug of bleach. Tested tonight and it turned pink!
    FC = 5ppm
    CC = 5.5ppm
    Looks like I should be good on chlorine - I'm going to pick up some OTO tests to do daily checks. From what I read I should keep it between 3-6ppm.
    Re-tested pH and it's still either 7.8 or 8
    I did the acid test to see how high it was and it only took 1 drop before it went down to 7.4 so I don't think I need to mess with it.
    My thoughts now are that I need to add CYA to the pool and just keep tabs on the pH and Chlorine and make sure they don't drop.
    Right?
    14k Gal Concrete Oval Pool - Hayward DE6020 Filter
    Your chlorine numbers don't look right. At least I hope they aren't right because you certainly don't want a CC reading of 5.5!
    How did you get that reading? After you got your FC reading, did you add the 5 drops of R-0003 and then again, add drops of R-0871 til it turned clear? How many drops did it take to clear it?
    Have you watched the testing demo videos? http://pool9.net/K2006-vid/
    May 2014
    Texas
    It should probably say FC = 5ppm, CC = 0.5ppm, TC = 5.5ppm
    Yes, that's what I did, took 1 drop to clear after the R-0003.
    Quote Originally Posted by JustAlex4tw View Post
    Good. That is what I figured it was. Glad it's not a CC of 5.5!
    May 2014
    Texas
    Thanks for paying enough attention even though there are so many new posts! I appreciate you catching it!
    Should I add the stabilizer now?
