Results 11 to 20 of 20
Thread: First testing with K-2006
    mommak is offline Registered+ Thread Analyst mommak 0
    May 2014
    Michigan
    Default Re: First testing with K-2006
    Thanks a million Watermom. Your expertise and knowledge is greatly appreciated. Tonight I will begin my dose of borax and dichlor. When I test tomorrow morning I will post my numbers.
    Intex AG, 18' x 48", 7,500 gallons,
    Intex Sand Filter-SF 20110
    K-2006 Test Kit
    You are welcome. Glad that we can help.
    May 2014
    Michigan
    Okay, this morning testing didn't go as well. Here's my results,
    FC- 5.0
    CC- after 10 drops of R-0871 10 ml didn't turn pink
    pH- 8.0 before adding 5 drops of R-0004, then after adding 3 drops of R-0005 pH is 7.2
    Still no CYA, added 1 c. dichlor and 1 c. borax last night.
    What do I need to do and or add?
    K-2006 Test Kit
    BigDave's Avatar
    I think you may be doing the CC test incorrectly. To review:
    1)Add a scoop or two of DPD powder (R-0870) to 10ml sample. If it turns pink you have FC, do step 1.1. Otherwise FC=0, skip 1.1.
    1.1)Add drops of R-0871 counting drops and swirling until pink turns clear. Multiply drop count by 0.5 to get FC in ppm.
    2)Add 5 drops R-0003 to sample and swirl. If it turns pink you have CC, do step 2.1. Otherwise CC=0, skip 2.1.
    2.1)Add drops of R-0871 counting drops and swirling until pink turns clear. Multiply drop count by 0.5 to get CC in ppm.
    I think you should stop adding Borax until pH gets to 7.4.
    No need to test for CYA until you've used up a few pounds of dichlor, I'd wait until I used about eight pounds of dichlor before testing again.
    Last edited by BigDave; 06-06-2014 at 01:40 PM. Reason: Renumbered steps for clarity. The old step 3 is now step 2
    Are you following the Super Simple recipe?
    Have you watched the testing demo videos? http://pool9.net/K2006-vid/
  6. #16
    Just to reiterate for clarity --
    If you have NO pink on step 3 from Dave's post above, you do NOT add the drops of R-0871 on step 4.
  7. #17
    May 2014
    Michigan
    Yes, I am following the Super Simple Recipe. I did exactly what BigDave posted above, except for after I added the 5 drops of R-0003, my solution did not turn pink,so I kept adding more drops. After a total of 10 drops it still didn't turn pink,so I stopped adding the R-0003. Does this mean that my pool does not have Combined chlorine?
    I am a bit confused with the pH testing. Which pH result number is the accurate one to use? The result after I add the R-0004 or the one after I add the R-0005?
    I will hold off on testing for CYA until after I have used about 8lbs of the dichlor.
    K-2006 Test Kit
  8. #18
    BigDave's Avatar
    After adding 5 drops R-0004 you get a direct pH reading.
    R-0005 is acid and the test is used to estimate the amount of acid you'd need to bring the pool to a specific pH. We almost never ask anyone to do that test.
    If your pH is 8 after 5 drops of R-0004, skip the Borax doses.
    Sorry, Watermom, for messing up the step numbers.
  9. #19
    May 2014
    Michigan
    Thank you, yes I will stop adding borax until my pH level lowers.
    K-2006 Test Kit
  10. #20
    Quote Originally Posted by mommak View Post
    ...after I added the 5 drops of R-0003, my solution did not turn pink, so I kept adding more drops. After a total of 10 drops it still didn't turn pink,so I stopped adding the R-0003. Does this mean that my pool does not have Combined chlorine?
    That bolded text above is your mistake on the CC test. After you add the 5 drops of R-0003, if it does not turn pink, then you have no CC. You do not need to keep adding drops to try and make it turn pink.
  1. Testing cya with 2006
    By dansdad in forum DPD-FAS based testing
    Last Post: 06-01-2014, 05:29 PM
  2. Neutralize ch before testing ph on 2006?????
    By dansdad in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-04-2013, 10:47 PM
  3. Need Help Please - just got my taylor 2006 testing kit...
    By rannrich in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-16-2011, 03:41 PM
  4. Fine Tuning Testing Precedure w/ Taylor 2006
    By Gracy101 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-08-2006, 09:36 PM
  5. Testing chlorine with Taylor K-2006 kit?
    By AndieP in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-07-2006, 06:15 PM
