Great!
Start following the "Intex Pool Care Plan" section of the Super Simple Recipie. After using about eight pounds of dichlor, the CYA should be near 50. Don't test for CYA until you think you've used eight pounds. When CYA is near 50, you can return to chlorinating with bleach.
Congrats on the K-2006 - The first couple times it can be a bit intimidating but it's well worth it. I forgot to mention: don't worry about the CH for now, If you don't get scale or cloudy water, you may never need it.
@Watermom: Thanks for the volume![]()
