Results 1 to 10 of 20
Thread: First testing with K-2006
    mommak is offline Registered+ Thread Analyst mommak 0
    May 2014
    Michigan
    Default Re: First testing with K-2006
    Okay, this morning testing didn't go as well. Here's my results,
    FC- 5.0
    CC- after 10 drops of R-0871 10 ml didn't turn pink
    pH- 8.0 before adding 5 drops of R-0004, then after adding 3 drops of R-0005 pH is 7.2
    Still no CYA, added 1 c. dichlor and 1 c. borax last night.
    What do I need to do and or add?
    Intex AG, 18' x 48", 7,500 gallons,
    Intex Sand Filter-SF 20110
    K-2006 Test Kit
    BigDave's Avatar
    I think you may be doing the CC test incorrectly. To review:
    1)Add a scoop or two of DPD powder (R-0870) to 10ml sample. If it turns pink you have FC, do step 1.1. Otherwise FC=0, skip 1.1.
    1.1)Add drops of R-0871 counting drops and swirling until pink turns clear. Multiply drop count by 0.5 to get FC in ppm.
    2)Add 5 drops R-0003 to sample and swirl. If it turns pink you have CC, do step 2.1. Otherwise CC=0, skip 2.1.
    2.1)Add drops of R-0871 counting drops and swirling until pink turns clear. Multiply drop count by 0.5 to get CC in ppm.
    I think you should stop adding Borax until pH gets to 7.4.
    No need to test for CYA until you've used up a few pounds of dichlor, I'd wait until I used about eight pounds of dichlor before testing again.
    Last edited by BigDave; 06-06-2014 at 12:40 PM. Reason: Renumbered steps for clarity. The old step 3 is now step 2
    Are you following the Super Simple recipe?
    Have you watched the testing demo videos? http://pool9.net/K2006-vid/
    Just to reiterate for clarity --
    If you have NO pink on step 3 from Dave's post above, you do NOT add the drops of R-0871 on step 4.
    May 2014
    Michigan
    Yes, I am following the Super Simple Recipe. I did exactly what BigDave posted above, except for after I added the 5 drops of R-0003, my solution did not turn pink,so I kept adding more drops. After a total of 10 drops it still didn't turn pink,so I stopped adding the R-0003. Does this mean that my pool does not have Combined chlorine?
    I am a bit confused with the pH testing. Which pH result number is the accurate one to use? The result after I add the R-0004 or the one after I add the R-0005?
    I will hold off on testing for CYA until after I have used about 8lbs of the dichlor.
    K-2006 Test Kit
    BigDave's Avatar
    After adding 5 drops R-0004 you get a direct pH reading.
    R-0005 is acid and the test is used to estimate the amount of acid you'd need to bring the pool to a specific pH. We almost never ask anyone to do that test.
    If your pH is 8 after 5 drops of R-0004, skip the Borax doses.
    Sorry, Watermom, for messing up the step numbers.
    May 2014
    Michigan
    Thank you, yes I will stop adding borax until my pH level lowers.
    K-2006 Test Kit
    Quote Originally Posted by mommak View Post
    ...after I added the 5 drops of R-0003, my solution did not turn pink, so I kept adding more drops. After a total of 10 drops it still didn't turn pink,so I stopped adding the R-0003. Does this mean that my pool does not have Combined chlorine?
    That bolded text above is your mistake on the CC test. After you add the 5 drops of R-0003, if it does not turn pink, then you have no CC. You do not need to keep adding drops to try and make it turn pink.
