Results 1 to 10 of 20
Thread: First testing with K-2006
    BigDave's Avatar
    Default Re: First testing with K-2006
    I think you may be doing the CC test incorrectly. To review:
    1)Add a scoop or two of DPD powder (R-0870) to 10ml sample. If it turns pink you have FC, do step 1.1. Otherwise FC=0, skip 1.1.
    1.1)Add drops of R-0871 counting drops and swirling until pink turns clear. Multiply drop count by 0.5 to get FC in ppm.
    2)Add 5 drops R-0003 to sample and swirl. If it turns pink you have CC, do step 2.1. Otherwise CC=0, skip 2.1.
    2.1)Add drops of R-0871 counting drops and swirling until pink turns clear. Multiply drop count by 0.5 to get CC in ppm.
    I think you should stop adding Borax until pH gets to 7.4.
    No need to test for CYA until you've used up a few pounds of dichlor, I'd wait until I used about eight pounds of dichlor before testing again.
    Last edited by BigDave; 06-06-2014 at 12:40 PM. Reason: Renumbered steps for clarity. The old step 3 is now step 2
