Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 47 of 47
Thread: HELP dealing with mustard algae!
  1. #41
    May 2014
    South Carolina
    Default Re: UGh here comes the algae AGAIN
    OK -wasn't sure if I should just add on to old post. I had more of this algae this afternoon so I vacuumed to waste, brushed, added 3 more bottles of bleach around 5pm. Just took a sample and got these results
    FC 34.5
    CC 0.5
    pH 7.8
    TA 140
    How often should I check CYA? Should I put in more bleach tonight? Had to add more city water to fill pool after all this vacuuming to waste today. It is supposed to be clear and sunny for the next 48 hours with temps in the mid 90's
    18 x 36 vinyl IG pool; Tagelus sand filter; 3/4HP pump; booster for Pentair cleaner; SWCG, Taylor Test Kit
  2. #42
    When was the last time you added CYA or used a stabilized form of chlorine (trichlor or dichlor)?
    If you are at 34.5ppm, I don't think you need to add any more bleach tonight.
  3. #43
    May 2014
    South Carolina
    I have a bottle of stablizer I bought last month. Should I add it tonight? I had used a puck last week
  4. #44
    When was the last time you tested CYA and what was it then?
  5. #45
    May 2014
    South Carolina
    this morning before any bleach- CYA was 45
  6. #46
    You're ok for now. I wouldn't add any more CYA at this point. And, as long as you're not adding anymore, no reason to test it anytime soon.
  7. #47
    May 2014
    South Carolina
    Thanks Watermom - will check level in AM. Guessing that big drop in FC allowed algae to bloom.
  1. Dealing w/Algae for 3 weeks
    By TheKs in forum Dealing with Algae & Slime
    Last Post: 08-24-2012, 06:49 PM
  2. Dealing with the usual springtime algae
    By fog80 in forum Dealing with Algae & Slime
    Last Post: 05-17-2012, 07:33 PM
  3. Dealing with black algae (Part 1 of 2)
    By smallpooldad in forum Dealing with Algae & Slime
    Last Post: 07-13-2008, 12:28 AM
  4. Wanted: Mustard algae or suspected mustard algae
    Last Post: 08-30-2007, 09:40 PM
  5. Newbe dealing with Algae
    By zteller in forum Dealing with Algae & Slime
    Last Post: 06-02-2006, 07:27 AM
