Results 1 to 10 of 47
Thread: HELP dealing with mustard algae!
    May 2014
    South Carolina
    Default Re: FINALLY algae free x 2 days - NOW WHAT?
    Water is not 100% clear - hazy in deep end. Unfortunately I have to work the next 2 nights so I cant do that test until Sunday night. One question - what is a safe chlorine level for the kids to swim? I thought I would need to let the chlorine drop some before they can enter the pool. I can test water in mornings. Will post then Thanks Watermom!
    18 x 36 vinyl IG pool; Tagelus sand filter; 3/4HP pump; booster for Pentair cleaner; SWCG, Taylor Test Kit
    Personally, I'd let the chlorine drop quite a bit before swimming. It probably would not hurt you but it would be tough on swimwear. With a CYA of 60, I wouldn't have a problem swimming with the chlorine at 15 or so but that is personal opinion. Plus, if you have a hazy deep end, you have to be careful with being able to see your kids while they are in there. Post your numbers tomorrow.
    May 2014
    South Carolina
    OK rechecked today - no algae - deep end still hazy but getting clearer. Readings are
    FC 33.5
    CC0
    pH 7.6
    TA 140
    Did add a bag of salt as it was low (3100) after rain
